Run Time: 0.001142
Run Time: 0.000999
Run Time: 0.000444
Run Time: 0.002352
Run Time: 0.000469
;٧,
;٧, XF\Pub\Controller\Forum, List, valid, , 1715211666,
Run Time: 0.000137
Run Time: 0.000642
Params: 1715210766
Run Time: 0.000354
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 179 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715210766)
Run Time: 0.000490
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 179 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712619666)
Run Time: 0.001260
Run Time: 0.000827
Run Time: 0.000770
Run Time: 0.000227
Run Time: 0.001280
Run Time: 0.001879
