Run Time: 0.001651
Run Time: 0.000259
Run Time: 0.000774
Run Time: 0.000364
Run Time: 0.003064
Run Time: 0.000579
Params: 0, 8r, 8r, XF\Pub\Controller\Forum, List, valid, , 1715196829,
Run Time: 0.000151
Run Time: 0.000882
Params: 1715195929
Run Time: 0.000537
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715195929)
Run Time: 0.000671
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712604829)
Run Time: 0.001748
Run Time: 0.001319
Run Time: 0.001069
Run Time: 0.000302
Run Time: 0.000222
Run Time: 0.000263
Run Time: 0.000306
Run Time: 0.000353
Run Time: 0.000387
Run Time: 0.001888
Run Time: 0.000258
Run Time: 0.002194
