Run Time: 0.001189
Run Time: 0.000226
Run Time: 0.000728
Run Time: 0.000294
Run Time: 0.002322
Run Time: 0.000585
Params: 0, 4T, 4T, XF\Pub\Controller\Forum, List, valid, , 1714902237,
Run Time: 0.000143
Run Time: 0.000869
Params: 1714901337
Run Time: 0.000464
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 149 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714901337)
Run Time: 0.000597
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 149 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712310237)
Run Time: 0.001488
Run Time: 0.001160
Run Time: 0.000896
Run Time: 0.000397
Run Time: 0.000228
Run Time: 0.000311
Run Time: 0.001603
Run Time: 0.000225
Run Time: 0.002104
