Run Time: 0.001683
Run Time: 0.000803
Run Time: 0.000305
Run Time: 0.002603
Run Time: 0.000530
Params: 0, vȈ, vȈ, XF\Pub\Controller\Forum, List, valid, , 1714306604,
Run Time: 0.000873
Params: 1714305704
Run Time: 0.000300
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 78 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714305704)
Run Time: 0.000548
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 78 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711714604)
Run Time: 0.001364
Run Time: 0.001053
Run Time: 0.000854
Run Time: 0.000210
Run Time: 0.001421
Run Time: 0.001920
bytes_received | 941545 |
bytes_received_change_user_packet | 714428 |
bytes_received_real_data_ps | 702411 |
