Run Time: 0.001180
Run Time: 0.000229
Run Time: 0.000737
Run Time: 0.000286
Run Time: 0.002488
Run Time: 0.000752
Params: 0, ِ , ِ , XF\Pub\Controller\Forum, List, valid, , 1714261571,
Run Time: 0.000145
Run Time: 0.000848
Params: 1714260671
Run Time: 0.000361
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 72 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714260671)
Run Time: 0.000680
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 72 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711669571)
Run Time: 0.001529
Run Time: 0.001113
Run Time: 0.001473
Run Time: 0.000265
Run Time: 0.000305
Run Time: 0.000357
Run Time: 0.000356
Run Time: 0.001391
Run Time: 0.000152
Run Time: 0.002247
bytes_received | 941854 |
bytes_received_change_user_packet | 714737 |
proto_binary_fetched_bit | 2910 |
bytes_received_real_data_ps | 702688 |
