Run Time: 0.001299
Run Time: 0.000274
Run Time: 0.000255
Run Time: 0.000743
Run Time: 0.002680
Run Time: 0.000622
Params: 0, $, $, XF\Pub\Controller\Forum, List, valid, , 1715028454,
Run Time: 0.001147
Params: 1715027554
Run Time: 0.000487
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 113 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715027554)
Run Time: 0.000669
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 113 | Using where |
Run Time: 0.000351
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712436454)
Run Time: 0.001351
Run Time: 0.001459
Run Time: 0.001044
Run Time: 0.000349
Run Time: 0.000300
Run Time: 0.000226
Run Time: 0.000301
Run Time: 0.000351
Run Time: 0.002356
Run Time: 0.000229
Run Time: 0.004260
bytes_sent | 23302 |
bytes_received | 944418 |
packets_sent | 286 |
packets_received | 3431 |
protocol_overhead_in | 13724 |
bytes_received_change_user_packet | 719713 |
packets_sent_command | 142 |
result_set_queries | 46 |
ps_buffered_sets | 46 |
proto_binary_fetched_bit | 2941 |
proto_binary_fetched_json | 4498 |
com_stmt_prepare | 47 |
com_stmt_execute | 47 |
com_stmt_close | 46 |
bytes_received_real_data_ps | 707525 |
