Run Time: 0.001200
Run Time: 0.000771
Run Time: 0.000286
Run Time: 0.002386
Run Time: 0.000604
:', XF\Pub\Controller\Forum, List, valid, , 1715078715,
Run Time: 0.000159
Run Time: 0.000849
Params: 1715077815
Run Time: 0.000420
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 55 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715077815)
Run Time: 0.000625
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 55 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712486715)
Run Time: 0.002385
Run Time: 0.001229
Run Time: 0.000986
Run Time: 0.000225
Run Time: 0.000317
Run Time: 0.001913
Run Time: 0.000266
Run Time: 0.000345
Run Time: 0.003051
