Run Time: 0.001198
Run Time: 0.000702
Run Time: 0.000314
Run Time: 0.002536
Run Time: 0.000533
Params: 0, v , v , XF\Pub\Controller\Forum, List, valid, , 1714765364,
Run Time: 0.000139
Run Time: 0.000643
Params: 1714764464
Run Time: 0.000501
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 107 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714764464)
Run Time: 0.000591
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 107 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712173364)
Run Time: 0.001331
Run Time: 0.001039
Run Time: 0.000937
Run Time: 0.000575
Run Time: 0.000255
Run Time: 0.000291
Run Time: 0.001769
Run Time: 0.002207
