Run Time: 0.001273
Run Time: 0.000732
Run Time: 0.000293
Run Time: 0.002424
Run Time: 0.000536
Params: 0, t>-, t>-, XF\Pub\Controller\Forum, List, valid, , 1714812714,
Run Time: 0.000136
Run Time: 0.000687
Params: 1714811814
Run Time: 0.000376
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714811814)
Run Time: 0.000586
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 105 | Using where |
Run Time: 0.000159
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712220714)
Run Time: 0.001255
Run Time: 0.000979
Run Time: 0.000984
Run Time: 0.000244
Run Time: 0.000271
Run Time: 0.001648
Run Time: 0.003374
bytes_received | 942120 |
bytes_received_change_user_packet | 715003 |
proto_binary_fetched_bit | 2920 |
bytes_received_real_data_ps | 702964 |
