Run Time: 0.001441
Run Time: 0.000228
Run Time: 0.000826
Run Time: 0.000373
Run Time: 0.003129
Run Time: 0.000535
Params: 0, ޣ, ޣ, XF\Pub\Controller\Forum, List, valid, , 1714285965,
Run Time: 0.000814
Params: 1714285065
Run Time: 0.000481
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 125 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714285065)
Run Time: 0.000625
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 125 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711693965)
Run Time: 0.001323
Run Time: 0.000935
Run Time: 0.001030
Run Time: 0.000229
Run Time: 0.000335
Run Time: 0.000404
Run Time: 0.001519
Run Time: 0.000205
Run Time: 0.002478
bytes_received | 941547 |
bytes_received_change_user_packet | 714430 |
bytes_received_real_data_ps | 702413 |
