Run Time: 0.001153
Run Time: 0.000745
Run Time: 0.000326
Run Time: 0.002580
Run Time: 0.000574
;d*,
;d*, XF\Pub\Controller\Forum, List, valid, , 1715080692,
Run Time: 0.000147
Run Time: 0.000859
Params: 1715079792
Run Time: 0.000369
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 119 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715079792)
Run Time: 0.000563
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 119 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712488692)
Run Time: 0.001790
Run Time: 0.001174
Run Time: 0.000903
Run Time: 0.000189
Run Time: 0.000249
Run Time: 0.000302
Run Time: 0.000353
Run Time: 0.001681
Run Time: 0.002267
