Run Time: 0.001197
Run Time: 0.000695
Run Time: 0.000286
Run Time: 0.002402
Run Time: 0.000569
Params: 0, Y, Y, XF\Pub\Controller\Forum, List, valid, , 1714931964,
Run Time: 0.000132
Run Time: 0.000623
Params: 1714931064
Run Time: 0.000411
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 143 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714931064)
Run Time: 0.000538
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 143 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712339964)
Run Time: 0.001237
Run Time: 0.000953
Run Time: 0.000786
Run Time: 0.000255
Run Time: 0.000300
Run Time: 0.001517
Run Time: 0.002005
bytes_received | 946889 |
bytes_received_change_user_packet | 719772 |
proto_binary_fetched_bit | 2948 |
proto_binary_fetched_json | 4500 |
bytes_received_real_data_ps | 707567 |
