Run Time: 0.001199
Run Time: 0.000290
Run Time: 0.000768
Run Time: 0.000281
Run Time: 0.003176
Run Time: 0.000601
Params: 0, ޛ:, ޛ:, XF\Pub\Controller\Forum, List, valid, , 1714760445,
Run Time: 0.000816
Params: 1714759545
Run Time: 0.000526
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 155 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714759545)
Run Time: 0.000744
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 155 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712168445)
Run Time: 0.001479
Run Time: 0.001210
Run Time: 0.001166
Run Time: 0.000251
Run Time: 0.000347
Run Time: 0.000264
Run Time: 0.000351
Run Time: 0.001590
Run Time: 0.000324
Run Time: 0.002104
