Run Time: 0.001319
Run Time: 0.000708
Run Time: 0.000281
Run Time: 0.003003
Run Time: 0.000537
Params: 0, ޜK, ޜK, XF\Pub\Controller\Forum, List, valid, , 1714763584,
Run Time: 0.000143
Run Time: 0.000713
Params: 1714762684
Run Time: 0.000455
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 98 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714762684)
Run Time: 0.000622
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 98 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712171584)
Run Time: 0.001594
Run Time: 0.001067
Run Time: 0.000950
Run Time: 0.000279
Run Time: 0.001488
Run Time: 0.000185
Run Time: 0.001774
