Run Time: 0.001595
Run Time: 0.000366
Run Time: 0.000831
Run Time: 0.000351
Run Time: 0.002552
Run Time: 0.000622
Params: 0, uĸ, uĸ, XF\Pub\Controller\Forum, List, valid, , 1715092908,
Run Time: 0.000842
Params: 1715092008
Run Time: 0.000772
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 114 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715092008)
Run Time: 0.000627
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 114 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712500908)
Run Time: 0.001787
Run Time: 0.001450
Run Time: 0.001216
Run Time: 0.000269
Run Time: 0.000245
Run Time: 0.000266
Run Time: 0.000399
Run Time: 0.000427
Run Time: 0.002359
Run Time: 0.000349
Run Time: 0.000254
Run Time: 0.002320
bytes_received | 946644 |
bytes_received_change_user_packet | 719527 |
bytes_received_real_data_ps | 707334 |
