Run Time: 0.001398
Run Time: 0.000205
Run Time: 0.000869
Run Time: 0.000344
Run Time: 0.002899
Run Time: 0.000615
Params: 0, w~P, w~P, XF\Pub\Controller\Forum, List, valid, , 1714767374,
Run Time: 0.000788
Params: 1714766474
Run Time: 0.000404
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 79 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714766474)
Run Time: 0.000553
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 79 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712175374)
Run Time: 0.001378
Run Time: 0.001182
Run Time: 0.000945
Run Time: 0.000269
Run Time: 0.000277
Run Time: 0.000304
Run Time: 0.001485
Run Time: 0.000250
Run Time: 0.002101
