Run Time: 0.001875
Run Time: 0.000401
Run Time: 0.000444
Run Time: 0.001365
Run Time: 0.000632
Run Time: 0.004192
Run Time: 0.000884
Params: 0, k, k, XF\Pub\Controller\Forum, List, valid, , 1714322298,
Run Time: 0.001113
Params: 1714321398
Run Time: 0.000941
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 55 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714321398)
Run Time: 0.000718
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 55 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711730298)
Run Time: 0.002495
Run Time: 0.002411
Run Time: 0.002252
Run Time: 0.000538
Run Time: 0.000381
Run Time: 0.000497
Run Time: 0.000528
Run Time: 0.000424
Run Time: 0.000628
Run Time: 0.002093
Run Time: 0.000316
Run Time: 0.000328
Run Time: 0.002686
bytes_received | 941537 |
bytes_received_change_user_packet | 714420 |
bytes_received_real_data_ps | 702403 |
