Run Time: 0.001176
Run Time: 0.000738
Run Time: 0.000331
Run Time: 0.004251
Run Time: 0.000750
Params: 0, ٶ-, ٶ-, XF\Pub\Controller\Forum, List, valid, , 1715075849,
Run Time: 0.000768
Params: 1715074949
Run Time: 0.000461
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 94 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715074949)
Run Time: 0.000596
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 94 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712483849)
Run Time: 0.001623
Run Time: 0.001074
Run Time: 0.001013
Run Time: 0.000205
Run Time: 0.000272
Run Time: 0.000150
Run Time: 0.000294
Run Time: 0.001449
Run Time: 0.000189
Run Time: 0.001958
