Run Time: 0.001217
Run Time: 0.000243
Run Time: 0.000424
Run Time: 0.001306
Run Time: 0.000820
Run Time: 0.003178
Run Time: 0.000683
Params: 0, wnt, wnt, XF\Pub\Controller\Forum, List, valid, , 1714759733,
Run Time: 0.001399
Params: 1714758833
Run Time: 0.000479
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 132 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714758833)
Run Time: 0.000623
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 132 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712167733)
Run Time: 0.001566
Run Time: 0.000938
Run Time: 0.001044
Run Time: 0.000309
Run Time: 0.000222
Run Time: 0.000226
Run Time: 0.000433
Run Time: 0.001704
Run Time: 0.000233
Run Time: 0.000287
Run Time: 0.002812
