Run Time: 0.001583
Run Time: 0.000364
Run Time: 0.000263
Run Time: 0.000975
Run Time: 0.000359
Run Time: 0.003453
Run Time: 0.000746
Params: 0, Gn, Gn, XF\Pub\Controller\Forum, List, valid, , 1715758464,
Run Time: 0.001479
Params: 1715757564
Run Time: 0.000383
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 19 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715757564)
Run Time: 0.000652
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 19 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1713166464)
Run Time: 0.001629
SIMPLE | xf_thread | range | last_post_date | last_post_date | 4 | | 37 | Using where |
Run Time: 0.001265
Run Time: 0.001023
Run Time: 0.000282
Run Time: 0.000230
Run Time: 0.000767
Params: 24
Run Time: 0.000365
Run Time: 0.001720
WHERE (`xf_session_activity`.`user_id` = 852) AND (`xf_session_activity`.`unique_key` = '852')
Run Time: 0.002119
bytes_sent | 24606 |
bytes_received | 1014561 |
packets_sent | 322 |
packets_received | 3590 |
protocol_overhead_in | 14360 |
protocol_overhead_out | 1288 |
bytes_received_rset_header_packet | 1071 |
bytes_received_rset_row_packet | 293 |
bytes_received_prepare_response_packet | 227965 |
bytes_received_change_user_packet | 784020 |
packets_sent_command | 160 |
packets_received_rset_header | 119 |
packets_received_rset_row | 55 |
packets_received_prepare_response | 2859 |
packets_received_change_user | 502 |
result_set_queries | 52 |
ps_buffered_sets | 52 |
ps_prepared_once_executed | 52 |
rows_fetched_from_server_ps | 450 |
rows_buffered_from_client_ps | 450 |
rows_skipped_ps | 450 |
proto_binary_fetched_bit | 3262 |
proto_binary_fetched_bigint | 10629 |
proto_binary_fetched_decimal | 104 |
proto_binary_fetched_json | 5429 |
proto_binary_fetched_blob | 2028 |
com_stmt_prepare | 53 |
com_stmt_execute | 53 |
com_stmt_close | 52 |
bytes_received_real_data_ps | 769780 |
