Run Time: 0.001429
Run Time: 0.000263
Run Time: 0.000236
Run Time: 0.000713
Run Time: 0.000430
Run Time: 0.002338
Run Time: 0.000790
Params: 0, 4UL, 4UL, XF\Pub\Controller\Forum, List, valid, , 1715079486,
Run Time: 0.000141
Run Time: 0.000958
Params: 1715078586
Run Time: 0.000474
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 84 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715078586)
Run Time: 0.000704
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 84 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712487486)
Run Time: 0.001843
Run Time: 0.001686
Run Time: 0.001468
Run Time: 0.000290
Run Time: 0.000204
Run Time: 0.000274
Run Time: 0.000383
Run Time: 0.001453
Run Time: 0.000236
Run Time: 0.001847
