Run Time: 0.001156
Run Time: 0.000258
Run Time: 0.000815
Run Time: 0.000411
Run Time: 0.002636
Run Time: 0.000655
Params: 0, e<, e<, XF\Pub\Controller\Forum, List, valid, , 1715077583,
Run Time: 0.001130
Params: 1715076683
Run Time: 0.000468
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 128 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715076683)
Run Time: 0.000593
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 128 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712485583)
Run Time: 0.001703
Run Time: 0.001180
Run Time: 0.001164
Run Time: 0.000294
Run Time: 0.000326
Run Time: 0.000355
Run Time: 0.001694
Run Time: 0.002120
