Run Time: 0.000905
Run Time: 0.000763
Run Time: 0.000295
Run Time: 0.002640
Run Time: 0.000574
Params: 0, ukZ, ukZ, XF\Pub\Controller\Forum, List, valid, , 1714813239,
Run Time: 0.000139
Run Time: 0.000669
Params: 1714812339
Run Time: 0.000417
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 164 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714812339)
Run Time: 0.001004
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 164 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712221239)
Run Time: 0.001227
Run Time: 0.001003
Run Time: 0.000783
Run Time: 0.000247
Run Time: 0.000284
Run Time: 0.000294
Run Time: 0.001373
Run Time: 0.002040
bytes_received | 942120 |
bytes_received_change_user_packet | 715003 |
proto_binary_fetched_bit | 2920 |
bytes_received_real_data_ps | 702964 |
