Run Time: 0.001386
Run Time: 0.000678
Run Time: 0.002353
Run Time: 0.000542
Params: 0, Y, Y, XF\Pub\Controller\Forum, List, valid, , 1715029379,
Run Time: 0.000132
Run Time: 0.000632
Params: 1715028479
Run Time: 0.000573
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 120 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715028479)
Run Time: 0.000614
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 120 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712437379)
Run Time: 0.001361
Run Time: 0.001041
Run Time: 0.000800
Run Time: 0.000233
Run Time: 0.000369
Run Time: 0.000470
Run Time: 0.001410
Run Time: 0.002135
