Run Time: 0.001156
Run Time: 0.000192
Run Time: 0.000196
WHERE (`xf_thread`.`thread_id` = '235')
Run Time: 0.000760
WHERE (`xf_post`.`thread_id` = 235) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.000864
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 2 | Using where; Using filesort |
Run Time: 0.000255
Run Time: 0.000238
Params: 235
Run Time: 0.000106
Run Time: 0.000682
Run Time: 0.000279
Run Time: 0.002775
Run Time: 0.000565
WHERE (`xf_thread`.`title` LIKE '%Stajerlere%') AND (`xf_thread`.`title` LIKE '%altın%') AND (`xf_thread`.`title` LIKE '%tavsiyeler%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 235) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006845
WHERE (`xf_thread`.`title` LIKE '%Stajerlere%') AND (`xf_thread`.`title` LIKE '%altın%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 235) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006728
WHERE (`xf_thread`.`title` LIKE '%Stajerlere%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 235) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006594
WHERE (`xf_thread`.`title` LIKE '%altın%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 235) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006669
WHERE (`xf_thread`.`title` LIKE '%altın%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 235) AND (`xf_thread`.`thread_id` <> 1324) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006654
WHERE ((`xf_thread`.`thread_id` = 1324))
Run Time: 0.000254
Params: 0, t4, t4, XF\Pub\Controller\Thread, Index, valid, thread_id=235, 1716176720,
Run Time: 0.000121
Run Time: 0.000683
Run Time: 0.001251
WHERE (`xf_session_activity`.`user_id` = 320) AND (`xf_session_activity`.`unique_key` = '320')
Run Time: 0.000243
Run Time: 0.000188
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1713584720)
Run Time: 0.001477
Run Time: 0.000910
Run Time: 0.000361
Run Time: 0.000278
Run Time: 0.002173
bytes_sent | 56905 |
bytes_received | 964637 |
packets_received | 3826 |
protocol_overhead_in | 15304 |
bytes_received_rset_header_packet | 990 |
bytes_received_prepare_response_packet | 254688 |
bytes_received_change_user_packet | 707427 |
packets_received_rset_header | 110 |
packets_received_prepare_response | 3136 |
packets_received_change_user | 468 |
rows_fetched_from_server_ps | 416 |
rows_buffered_from_client_ps | 416 |
rows_skipped_ps | 416 |
proto_binary_fetched_bit | 2899 |
proto_binary_fetched_short | 2254 |
proto_binary_fetched_int24 | 820 |
proto_binary_fetched_bigint | 7788 |
proto_binary_fetched_float | 125 |
proto_binary_fetched_json | 4226 |
proto_binary_fetched_blob | 1697 |
bytes_received_real_data_ps | 695798 |
