Java,Forth,Pascal,VHDL
    Delphi/Pascal
Co.Admin
Co.Admin
Üye No: 92
Kayıt: 05.11.2006
Puan: 1921
MesajTarih: 24/4/2007, 21:06    Mesaj konusu: Java,Forth,Pascal,VHDL Alıntıyla Cevap Gönder
[Linki görmek için üye olmanız gerekmektedir]
Computer Programming
* Art of Assembly language [pdf,tgz]
* Art of Assembly language (High Level Assembler) [pdf]
* Thinking in C++, 2nd Edition, Volume 2 [online(frames,no frames)]
* Thinking in C++, 2nd Edition, Volume 2, Example Codes [online,tgz]
* C++ Programming style [txt]
* Multithreaded Programming Guide (Sun Microsystems) [pdf]
* POSIX.1c/D10 Summary (Sun Microsystems) [ps,pdf]
* pthreads and Solaris threads: A comparison of two user level threads APIs (Sun Microsystems) [ps,pdf]
* Thinking in Java, 2nd Edition [online(frames,no frames)]
* Thinking in Java, 2nd Edition, Example Codes [online,tgz]
* Intel Architecture optimizations [pdf]
* HTML 4.0 Reference [online]
* Data Display Debugger (DDD) 3.3.1 Manual [online]
* Writing Multithreaded Code in Solaris [pdf]
* Intel Architecture Optimization Manual [pdf]
* Intel Architecture Software Developer's Manual, Volume 1, Basic Architecture [pdf]
* Intel Architecture Software Developer's Manual, Volume 2, Instruction Set Reference [pdf]
* Intel Architecture Software Developer's Manual, Volume 3, System Programming [pdf]
* Performance of Various Computers Using Standard Linear Equations Software [pdf]
* The SPARC Architecture Manual, Version 8 [pdf]
* The SPARC Architecture Manual, Version 9 [pdf]
* UltraSPARC I-II User's Manual [pdf]
* UltraSPARC IIi User's Manual [pdf]
* microSPARC IIep User's Manual [pdf]
* SuperSPARC II Addendum [pdf]
* Alpha Architecture Handbook, Version 4 [pdf]
* System V Application Binary Interface, Edition 4.1 [pdf]
* System V Application Binary Interface, Intel386 Architecture Processor Supplement, Edition 4 [pdf]
* MIPS R4000 Microprocessor User's Manual, 2nd Edition [pdf]
* The 32-bit PA-RISC Run-time Architecture Document, HP-UX 10.20, Version 3 [pdf]
* The 32-bit PA-RISC Run-time Architecture Document, HP-UX 11.00, Version 1 [pdf]
* ANSI/ISO C++ Professional Programmer's Handbook [pdf]
VHDL
* VHDL CookBook by Peter J. Ashenden [pdf]
* Analog and Mixed-Signal Modeling using VHDL-AMS [pdf]
* European Space Agency (ESA) VHDL Modelling Guidelines [pdf]
* US Navy VHDL Modelling Guide [pdf(1,2,3,4,5,6,7)]
Operating systems
* Introduction to OS [pdf]
* Process scheduling [pdf]
* Resource management and deadlocks [pdf]
* I/O Management [pdf]
* Filesystem [pdf]
* Memory management [pdf]
* Interprocess communication [pdf]
* System security [pdf]
Cryptography
* A Cryptography Tutorial [summary,pdf(1,2,3,4,5,6,7,Cool]
* Another Cryptography tutorial [pdf(1,2,3,4,5,6,7)]
* Cryptography - The myths [pdf]
* A Cryptograpgic Compendium [link]
* Frequently Asked Questions about Today's Cryptography by RSA Laboratories [pdf]
* Security protocols overview by RSA Laboratories [pdf]
* Security Pitfalls in Cryptography [pdf]
* Stream ciphers [pdf]
* Understanding Public Key Infrastructure [pdf]
* Trust Models and Management in Public-Key Infrastuctured [pdf]
* Why Cryptography is Harder than it looks [pdf]
* Cryptanalytic Attacks on Pseudorandom Number Generators [pdf]
* CryptoBytes, RSA newsletter [pdf(1-1,1-2,1-3,2-1,2-2,2-3,3-1,3-2,4-1,4-2)]
* RSA Laboratories' Bulletin [pdf(1,2,3,4,5,6,7,8,9,10,11,12,13)]
* Smartcard security [pdf]
* Digital Signatures, Certificates and Electronic Commerce [pdf]
* Key recovery - Meeting the Needs of Users or Key Escrow in Disguise [pdf]
* Implementation Experience with AES Candidate Algorithms [pdf]
* Performance Analysis of AES candidates on the 6805 CPU core [pdf]
* UK Government Organisations Involved in Communications and Information Systems Security [pdf]
* The block cipher Square [pdf]
* Attacks on Cryptoprocessor Transaction Sets [pdf]
* Initial Cryptanalysis of the RSA SecurID Algorithm [pdf]
* Amplified Boomerang Attacks Against Reduced-Round MARS and Serpent [pdf]
* Preliminary Cryptanalysis of Reduced-Round Serpent [pdf]
* Defective Sign and Encrypt in S/MIME, PKCS#7, MOSS, PEM, PGP, and XML [pdf]
* Compliance Defects in Public-Key Cryptography [pdf]
* Architectural considerations for cryptanalytic hardware [pdf]
* WEP Fix using RC4 Fast Packet Keying [pdf]
* RSA Security Response to Weaknesses in Key Scheduling Algorithm of RC4 [pdf]
* Block Ciphers [pdf]
* Stream Ciphers [pdf]
* C.R.I.S.I.S. - Cryptography's Role In Securing the Information Society [pdf]
* Universal Hashing and Multiple Authentication [pdf]
* Timing Analysis of Keystrokes and Timing Attacks on SSH [pdf]
* The simple ideal cipher system [pdf]
* An FPGA Implementation of the Linear Cruptanalysis [pdf]
* The math behind the RSA cipher [txt]
* RSA hardware implementation [pdf]
* High-Speed RSA implementation [pdf]
* Are 'Strong' Primes Needed for RSA? [pdf]
* RSAES-OAEP Encryption scheme [pdf]
* Has the RSA algorithm been compromised as a result of Bernstein's Papar? [pdf]
* Are 'Strong' Primed Needed for RSA? [pdf]
* Why Textbook ElGamal and RSA Encryption are Insecure [pdf]
* The DES algorithm [txt]
* The RC5 encryption algorithm [pdf]
* On The Security of the RC5 Encryption Algorithm [pdf]
* The ESP RC5-CBC Transform [txt]
* The RC5, RC5-CBC, RC5-CBC-Pad, and RC5-CTS Algorithms [txt]
* The RC6 block cipher [pdf]
* RC6 as the AES [pdf]
* The security of RC6 block cipher [pdf]
* Statistical testing of RC6 block cipher [pdf]
* Blowfish algorithm in plain English [txt]
* Source code for Blowfish implementation [zip(C++,Another C++,Java,ANSI C,Another ANSI C,Forth,Pascal)]
* Twofish: A 128-bit Block Cipher [pdf]
* Upper bounds on differential characteristics in Twofish [pdf]
* Impossible differentials in Twofish [pdf]
* A Twofish retreat: Related-Key attacks against Reduced-Round Twofish [pdf]
* Further observations on the Key Schedule of Twofish [pdf]
* Empirical verification of Twofish key uniqueness properties [pdf]
* Key separation in Twofish [pdf]
* Improved Twofish implementations [pdf]
* Implementation of the Twofish Cipher using FPGA devices [pdf]
* Source code for Twofish implementation [zip(6805(Smartcard),Z80,Reference C code,ANSI C and i386 asm,Optimised ANSI C,Optimised C code [Linux code],Visual Basic,Java)]
* The Rijndael Block Cipher [pdf]
* A Specification of Rijndael, the AES Algorithm [pdf]
* Efficient Implementation of the Rijndael S-box [pdf]
* The Elliptic Curve Cryptosystem [pdf]
* Elliptic Curce Cryptosystems [pdf]
* Elliptic Curve Cryptography, Future Resiliency and High Security Systems [pdf]
* The Elliptic Curve Cryptosystem for Smart Cards [pdf]
* The Elliptic Curve Digital Signature Algorithm (ECDSA) [pdf]
* Recommendation on Elliptic Curve Cryptosystems [pdf]
* Elliptic Curve Cryptosystems on Reconfigurable Hardware [pdf]
Security
* Program Stack vulnerability [txt]
* Non-executable Program Stack vulnerability [txt]
* Strange Attractors and TCP/IP Sequence Number Analysis [link]
* Rainbow book series [link]
* Kernel Level Vulnerabilities, Behind the Scenes of the 5th Argus Hacking Challenge [pdf]
* Attacks on and Countermeasures for USB Hardware Token Devices [pdf]
* UNIX Assembly Codes Development for Vulnerabilities Illustration Purposes [pdf]
* Countermeasures against Buffer Overflow Attacks [pdf]
* Integrating Flexible Support for Security Policies into the Linux Operating System [pdf]
* Flaw in NTRU Signature Scheme (NSS) [pdf]
* Meeting Critical Security Objectived with Security-Enhanced Linux [pdf]
* Secure Programming with Linux and Unix [pdf]
* Reverse Compilation Techniques [pdf]
* What Should be Hidden and Open in Computer Security: Lessons from Deception, the Art of War, Law, and Economic Theory [pdf]
* Stack Smashing Vulnerabilities in the UNIX Operation System [pdf]
Networking
* Networking concepts [pdf]
* Introduction to Internet Protocols [txt]
* Network planning and design [pdf]
* Queuing analysis [pdf]
* Parallel FTP performance in a High-Bandwidth High-Latency WAN [pdf]
* Compete WAP Security [pdf]
* Cryptographic Authentication fo Real-Time Network Protocols [pdf]
* Temporary Committee on the ECHELON Interception System Report (Working Document) [pdf]
* IP Multicast Configuration [pdf]
* Can Shortest-path Routing and TCP Maximize Utility [pdf]
* A new TCP congestion control with empty queues and scalable stability [pdf]
* FAST Kernel: Backgroung Theory and Experimental Results [pdf]
* Robustness and the Internet: Design and evolution [pdf]
* Robust congestion control for the Internet [pdf]
* A Mathematical Framework for Designing a Low-Loss, Low-Delay Internet [pdf]
* On the stability of networks operating TCP-like congestion control [pdf]
* Ultrascale Network Protocols for Computing and Science in the 21st Century [pdf]
Computer Clusters
* High Performance Computing and Beowulf Clusters [pdf]
* Web Search for a Planet: The Google Cluster Architecture [pdf]
Bluetooth
* Specification of the Bluetooth System v1.1 22-02-2001 (Core) [pdf]
* Specification of the Bluetooth System v1.1 22-02-2001 (Profiles) [pdf]
* SyncML Over Bluetooth [pdf]
* Bluetooth Network Encapsulation Protocol (BNEP) Specification [pdf]
* Bluetooth Extended Service Deiscovery Profile (ESDP) for Universal Plug and Play (UPnP) [pdf]
* Personal Area Networking (PAN) Profile [pdf]
* Bluetooth Security White Paper [pdf]
* Security Comparison: Bluetooth vs 802.11 [pdf]
Mathematics
* SOS Mathematics [link]
* Mathematics archives [link]
* Dave's math tables [link]
* On-line Encyclopedia of Integer Sequences [link]
* Notes on Fermat's Last Theorem by A. J. Van Der Poorten [pdf(1,2,3,4,5,6,7,Cool]
* p-adic Chaos and Random Number Generation [pdf]
* Introduction to Probability Theory [pdf]
* Calculus - One-Variable Calculus, with an Introduction to Linear Algebra [pdf]
* Introduction to Methods of Applied Mathematics or Advances Mathematical Methods for Scientists and Engineers [pdf]
* Tables of Integrals and other Mathematical data [pdf]
* Random Generators and Normal Numbers [pdf]
* Ramanujan's Notebooks [pdf(pdf,pdf)]
* Prime Percolation [pdf]
* Prime Numbers with a Fixed Number of One Bits or Zero Bits in Their Binary Representation [pdf]
* Perturbation Theory of Dynamical Systems [pdf]
* On Fourier and Zeta(s) [pdf]
* Newton's Formula and the Continued Fraction Expansion of sqrt(d) [pdf]
* Linear Algebra [pdf]
* Linear Algebra - Answers [pdf]
* New Representations for the Madelung Constant [pdf]
* Sums of Squares, Cubes, and Higher Powers [pdf]
* Computing A Glimpse of Randomness [pdf]
* Computing the Generating Function of a Series Given its First Few Terms [pdf]
* Asymptotic Behavior of Excitable Cellular Automata [pdf]
* An Efficient Algorithm for Computing the Ith Letter of phi^n(a).pdf [pdf]
* Algebraic Topology [pdf]
* A Proof of a Conjecture of Knuth [pdf]
* A Practical Version of the Generalized Lagrange Algorithm [pdf]
Engineering
* Theoretical Computer Science cheat sheet [pdf]
* A mathematical theory of Communication [pdf]
* A Primer on Asynchronous Modem Communication [pdf]
* Dictionary of Algorithms, Data Structured, and Problems [link]
* Computing dictionary [link]
* Acronym lookup engine [link]
* StudyWeb search engine [link]
UNIX
* Unix is a Four Letter Word, and Vi is a Two Letter Abbreviation [pdf]
* Some useful UNIX Commands written down by Razor for newbies to get a start in UNIX [pdf]
* UNIX [pdf]
* Intermediate Unix Training [pdf]
* VI lovers [link]
* Unix Programming Tools [pdf]
* Unix history timeline (1969-2000) [pdf]
* Executable and Linkable Format (ELF) [txt]
* A Whirlwind Tutorial on Creating Really Teensy ELF Executables for Linux [online]
* Guide to Unix IPC [link]
* The Linux Kernel API [pdf]
* Unreliable guide to Linux kernel locking [pdf]
* Unreliable guide to hacking the Linux kernel [pdf]
* Linux 2.4 NAT Howto [pdf]
* Linux advanced routing Howto [pdf]
* Linux Netfilter hacking Howto [pdf]
* Samba 2.2 [online]
* Samba TNG [online]
USENIX
* Token-Mediated Certification and Electronic Commerce [pdf]
* The Linux BIOS [pdf]
* LOBOS: (Linux OS Boots OS) Booting a kernel in 32-bit mode [pdf]
Miscelaneous
* CVS Manual [online]
* The Ultimate Memory Guide [pdf]
* The RAM Guy's Tech Notes [link]
* Sun-Tzu The Art of Warfare [online]
* Ko Ko Ko [avi]
Uploader
Üye No: 9436
Kayıt: 18.08.2007
Puan: 10
Şehir: LosAngeles-Sydney
MesajTarih: 30/8/2007, 13:02    Mesaj konusu: Alıntıyla Cevap Gönder
iyi bir kaynak, teşkekürler.
iyi çalışmalar
Kullanıcı bilgilerini göster Kişisel mesaj gönder E-Posta gönder Kullanıcının web sitesini ziyaret et
Uploader
Üye No: 9436
Kayıt: 18.08.2007
Puan: 10
MesajTarih: 1/9/2007, 01:57    Mesaj konusu: dosyalarda virüs var... Alıntıyla Cevap Gönder
sayfada ki bazı dosyalarda backdoor ve benzeri tehlikeli virüsler var. indirmeden yada enazından indirdikten sonra elinizde ki sağlam bir anti-virus testinden geçirmenizi öenmle rica ederim.
herkese iyi çalışmalar.
    Delphi/Pascal
Yeni mesaj yok Önemli: Java Hakkında 10 GB 'lık Kaynak aabanozcu PHP/ASP/HTML/CGI/JAVA/PYTHON 108 22/2/2018, 23:43 Son gönderilen mesajlar
prony
Yeni mesaj yok VHDL:Programming by Example huso VB/C,C++,/Fortran 0 28/12/2007, 22:59 Son gönderilen mesajlar
Yeni mesaj yok BE Java Expert (good java books) huso PHP/ASP/HTML/CGI/JAVA/PYTHON 0 13/6/2009, 10:51 Son gönderilen mesajlar
Yeni mesaj yok Effective Java, 2nd Edition (The Java... kocayusuf13 PHP/ASP/HTML/CGI/JAVA/PYTHON 0 7/1/2012, 13:32 Son gönderilen mesajlar
kocayusuf13
Yeni mesaj yok Java programlama Dili,java'ya giriş huso PHP/ASP/HTML/CGI/JAVA/PYTHON 1 9/3/2008, 23:28 Son gönderilen mesajlar
miramax
Yeni mesaj yok Introduction to VHDL videosu huso Bilgisayar/Elektrik&Elektronik ve Haberleşme Mühendisleri 0 10/9/2009, 15:24 Son gönderilen mesajlar
Yeni mesaj yok VHDL türkçe kaynak burock Cisco ,MCSE ..vb Ağ Yönetimi/Sistem Yönetimi ve Mühendisliği 0 29/10/2009, 20:55 Son gönderilen mesajlar
burock
Yeni mesaj yok Evita VHDL Tutorial huso Bilgisayar/Elektrik&Elektronik ve Haberleşme Mühendisleri 0 10/9/2009, 13:07 Son gönderilen mesajlar
Yeni mesaj yok VHDL türkçe eğitim notları huso Bilgisayar/Elektrik&Elektronik ve Haberleşme Mühendisleri 0 10/9/2009, 13:06 Son gönderilen mesajlar
Yeni mesaj yok VHDL Tutorial-Türkçe - 224 sayfa isuldur Bilgisayar/Elektrik&Elektronik ve Haberleşme Mühendisleri 2 10/9/2009, 13:08 Son gönderilen mesajlar
Kod Çalışma Süresi = 0.1289 saniye, SQL Sorgu Adedi = 27, GZIP = Kapalı Hata denetimi = Kapalı,
147934 Saldırı girişimi engellendi
